April 25, 2024, 07:51:30 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Store
Calendar
Login
Register
Archive
Archive board
Engine Shop
Fuel pressure question
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Fuel pressure question (Read 4385 times)
MurderedGolf
Guest
on:
May 01, 2013, 09:02:40 am »
Does anyont know how much fuel pressure i should run with a solex 28 pict-1
PLATINUM Member
Offline
Gender:
Herby
Re: Fuel pressure question
Reply #1 on:
May 01, 2013, 02:20:02 pm »
My VW of America Without Guesswork book says 3 to 5 pounds per square inch (psi)
'56 Oval Nigel '53 Zwitter Project Stanley
MurderedGolf
Guest
Reply #2 on:
May 01, 2013, 02:21:53 pm »
Thanks i need to know so i know what electric fuel pump to get
Club Vice President
PLATINUM Member
Offline
Gender:
SYNCRO HiTop----K2SMD
Reply #3 on:
May 08, 2013, 12:38:47 pm »
42 S with your small carb (3.5 PSI max
12S (with the addition of a regulator) for a bigger carb
The VWs you can
in are more gooder
PLATINUM Member
Offline
Gender:
Reply #4 on:
May 08, 2013, 02:53:35 pm »
Quote from: Baha (Shawn) on May 08, 2013, 12:38:47 pm
I ran one of the pumps above off the shelf from pepboys, along with a pressure regulator and never had a problem...
Club Vice President
PLATINUM Member
Offline
Gender:
Reply #5 on:
May 08, 2013, 02:55:48 pm »
There's one on the Blue Meanie
The VWs you can
in are more gooder
PLATINUM Member
Offline
Reply #6 on:
May 08, 2013, 03:44:46 pm »
Baja have a regulator?
Club Vice President
PLATINUM Member
Offline
Gender:
Reply #7 on:
May 08, 2013, 09:59:20 pm »
Baja has a Weber carb. pressure was at 6.
Didn't put a regulator on but I did put clamps on the feed hoses
The VWs you can
in are more gooder
Print
Pages: [
1
Go Up
« previous
next »
Archive
Archive board
Engine Shop
