Author Topic: Ospho  (Read 16925 times)
Ospho
« on: May 06, 2015, 09:31:20 am »
Not sure if you guys have ever heard of Ospho, but I have been using it to convert rust before painting and it works great!  I spray it on the rust and overnight the rust (iron oxide) is converted to iron phosphate .  Not only that, but is also etches the metal to allow for better paint adhesion.  It is easy to use (spray or brush on), but it contains phosphoric acid, therefore you need to adhere to proper safety procedures (masks, gloves, goggles, no skin exposed, etc...) when handling it.
I have had great results using this product.  Just thought i would share my experience with using this awesome product.  I believe Ace Hardware carries it.
If your doing rust repair/neutralizing and can't just cut it out and replace metal, I believe this will help.  It helped me while repairing the Benz, since replacement parts were just too expensive.  I blasted everything i could and then ospho to paint.  Saved me hundreds of dollars.
http://www.ospho.com
  • Global Moderator
Re: Ospho
« Reply #1 on: May 06, 2015, 01:25:25 pm »
Do you have.to neutralize the ospho prior to priming?
Re: Ospho
« Reply #2 on: May 06, 2015, 02:24:59 pm »
Hey Richard,
You must rinse after allowing Ospho to set up overnight.   I rinse (water) and use pre-paint cleaner afterwards to neutralize.  I also use pre-paint cleaner before Ospho to prep for Ospho.  After neutralizing, Prime and paint.  Extreme rust may need two applications of Ospho before prime/paint.
-Celly
ps.  Nice job on the Bug, wish i could help, but I have been prepping for exams.
Re: Ospho
« Reply #3 on: May 06, 2015, 03:05:36 pm »
Same stuff we used Richard... POR 15 Metal Ready is essentially the same formula.
Re: Ospho
« Reply #4 on: May 06, 2015, 04:43:57 pm »
It's close no doubt...but there are differences
I hate to reinvent the wheel so....here ya go
http://www.shamrockboatownersclub.com/forums/archive/index.php/t-26678.html
I like POR, but I LOVE Ospho and I have used both.  I also prefer Ospho vs Rust Bullet (and i have used both)
Por needs to be primed (with their primer) in order to resist UV rays.  I have seen POR flake iwhen exposed to sun.  So, if your por coating is exposed to the sun, be sure to primer it and paint it.
Ospho doesn't need a special topcoat or special primer.  Ospho just needs to be neutralized and primered (with any primer).
  • Global Moderator
Re: Ospho
« Reply #5 on: May 06, 2015, 07:18:23 pm »
Thanks for the info, guys. Just trying to learn AMAP.
Eucel, while it would be great to have you helping, I totally understand the need to hit the books. Good luck with your exams!
Re: Ospho
« Reply #6 on: May 06, 2015, 09:23:36 pm »
Information is why I started this thread.  Questions are the lock and knowledge is the key. old-\
Thanks for the luck, I'm gonna need it! =distroy
Also my name is Yucel, but you can call me Celly 11&*
  • Global Moderator
Re: Ospho
« Reply #7 on: May 06, 2015, 10:45:32 pm »
Lol, I knew your name is Yucel. Not sure where "Eucel" came from. I'll just claim a senior moment and leave it at that!
Celly it is...
Re: Ospho
« Reply #8 on: May 07, 2015, 06:05:41 am »
Looks like Ospho is available at West Marine...
BTW folks, this is heavy rubber glove stuff. Eye protection and ventilation. It does a great job but you need your PPE. Read the label
Re: Ospho
« Reply #9 on: May 07, 2015, 08:23:10 am »
Yeah this stuff is serious! You even have to be careful not to get it on concrete, since it reacts with concrete it will distort/dissolve it! =fire
Have fun and be careful. afrobanana\
Re: Ospho
« Reply #10 on: May 09, 2015, 07:16:48 pm »
look at you Celly being all educated and everything
Re: Ospho
« Reply #11 on: May 11, 2015, 08:57:31 pm »
Always looking to better myself John.  I'm still learning and loving every bit of it  stu\dy
It must be all those late nights in the garage...   afrobanana\
Re: Ospho
« Reply #12 on: May 12, 2015, 07:22:37 pm »
wrenching solves all your troubles
