I've seen some pictures lately where the gas line is going up the fan and down into the filter. Is this the way it is suppose to be? Right now my fuel line comes in stays low than the filter than the fuel pump. The way the other way was had the fuel line coming up the fan than the filter down to the fuel pump. This just seems like it would put a lot of strain on the fuel pump. I'm just worried that the fuel hose will get to hot. Are there pictures anywhere of the original way that these fuel lines ran? Is the rubber of the fuel line heat proof?
I'll be at the parade on Sunday with a freshly tuned, valve adjusted and...probably failed inpection sticker Bridgette.
P.S. any solution to the key jiggling in the ignition to start it?
-Greg- And Ms. Bridge
