Time for another stupid game!!! NEW GAME!!!
Started by 6T5 square, April 02, 2008, 05:13:52 PM
Ok Boys and Girls- time for another stupid game with a lesson attached! See who can guess what these are-
Board members are not allowed to answer for the first 24hrs. (ha ha!)
Easy, and the one on the right looks like it was doing it's job and I won't answer.
Whatever that is looks like it wasn't lined up right, the center looks rounded off on the one on the left. *shug* Just a guess.
Looks like shop manual for a T3 VW.....
With vw engine "thermostats" sitting on top of it.
Oil gally plugs ??? compressed push rod tubes ???thermostats
Quote from: 6d4vdub (jack) on April 02, 2008, 06:10:34 PM
Keep in mind , young man, that I cleaned them before I took the picture
Quote from: jthw8 on April 02, 2008, 07:21:43 PM
wisenheimer!
And so far-nobody has guessed correctly!
I see they are cleaned, but I can still see signs that they were doing their secondary job. SO MUCH for your cleaning.   :icon_wink:
Hmmmm. still thinking.............
                      and still working on Jacks hint..
is there a comprable peice in a type1?
50split(paul)
the drain plugs(17mm)from the bottom of a tranny w/magnetic tip to collect metal shavings.
OooOOooooo I bet that's it. It looks like it would make sense.
Quote from: 50split on April 02, 2008, 10:03:53 PM
YES! We have a winner!
I'm finishing up some of my winter work on weezer and as I went to check the trans fluid I noticed it was low. So i figured I was going to buy some gear oil anyway, I might as well change all the fluid. The two plugs in the photo are the bottom ones- not to be confused with the side one where you check the fluid. The two magnets collect any shavings (kinda like the one for your oil) so you don't have anything sloshing around in there.
So the plugs were cleaned and the new fluid is going in tommorrow. In the mean time, I was wondering- How many members are probably still driving around with the same gear oil that VW put in it? s#r
Another stupid game coming soon!
I liked your stupid game,  banaafro bring on another one. I think I'll do one.
<---- Still driving around with the original gear oil. I over slept the day I was suppose to go to Jacks to use his oil pump.  >:(
OK folks- now this should be an easy one- but I want the correct name for it, not the slang term!
Remmember- you old timers can't answer for 24 hours!
