Hey guys, Just wanted to know if anybody has their line out of the expansion tank re routed under the car instead of back to the canister. I read a thread on the samba about it, people said they have it re routed somewhere under the trunk. If any of you guys did this let me know, cause I'd like to see how this was done. I've seen pictures on how to replace the charcoal in the canister... but that seems like a PIA unless you have the plastic version of the canister. Some people no the thread talked about removing the expansion tank completely and just rerouting the fumes into the tank. I know now this is bad. I was thinking about re routing it under the down into the the spare tire well, and then down through the a hole towards the ground. The problem is it smells like gas, when I fill up past half a tank, or if If I make a turn to sharp.
Thanks again for your help!!!
Friday Projects
Help Dad with Brakes
Bang out Dents in Rear fender if I can find flat hammer John was talking about.
Re Rout fumes under car instead of back to the canister/ remove canister or paint it and set up a faux hook-up
Paint top pulley for fan belt black/learn how to re-install fan belt so I know what to do for emergencies.
Only have one day off a week, gotta use it wisely!!
Might not make it to the meeting Monday I have a job interview at Toyota... don't hurt me I  s3
