Author Topic: another carb question  (Read 2895 times)
marcr1
« on: May 25, 2008, 03:35:44 pm »
Sorry guys by no means am i a mechanic....
   jc whiney has two carbs listed how do i know which one i want.
Replaces all Solex-type 30 PICT-1, 2, 3 and 34 PICT-3, 4. For 1500 and 1600cc engines with idle cut-off valves. Comes with adapter plate that allows carbs to be mounted as a 34 PICT carb replacement.
and here is the disription for the other    Replaces 34 PICT-3, 4. With idle cut-off switch.
Re: another carb question
« Reply #1 on: May 25, 2008, 05:08:11 pm »
If you have a 34, you don't want to replace it with a smaller one. This is a GOOD CARB if you have a 34 already.
I'm not sure what you have on the car.
marcr1
« Reply #2 on: May 25, 2008, 08:10:52 pm »
I have a 74 super beetle so my guess is that it has the 34 pict in it.
« Reply #3 on: May 25, 2008, 09:03:14 pm »
Yes its a 34 and the link i posted will work great. Don't go with a smaller throated carb that needs an addapter to fit your intake.
kiko
« Reply #4 on: May 25, 2008, 09:12:10 pm »
theres a solex pict 34 on the samba right now
