Pages: [1] 2 3 4   Go Down
Author Topic: Garage Space Needed  (Read 20111 times)
Garage Space Needed
« on: July 21, 2008, 07:27:05 pm »
Would like to remove my engine this fall... preferably after English Town to fix oil leaks and add some...missing parts onto my motor.
Mechanic like most of you know wanted 300 dollars, If i can do this in a day I'd like to do this myself with some assistant from the crew.
We do not have a garage and dad doesn't want to drop the motor, saving money is important when you only make 9.25 an hour.
Please let me know if you can help.
This is what needs to be done... possibly.
Oil Cooler Seals
Valve Cover gaskets *replacing next oil change*
Front Seal
Installation of flaps thermostat etc.
Bottom Tin
Engine liner seal.
Let me know if anybody can help, If not I'll get another estimate from the shop in monroeville.
-Greg-
PS 60 wt does exist. I ended up getting straight 40.  BO** BO** BO** Leaking is less.
Re: Garage Space Needed
« Reply #1 on: July 21, 2008, 09:06:04 pm »
In the fall, if you are REALLY stuck for a garage you can use mine, (probably, but need to check my schedule at that time) I'm in Pa tho, and of course if we do not finish for whatever reason, you may have to stay over, - so you would have to pack your P-jamees, and bunny slippers. Katie loves reading bedtime stories, so your in luck there!
« Reply #2 on: July 21, 2008, 09:48:39 pm »
 shocked  $9.25 an hour? Gosh man get a job.
Please let me know if you can help. I can help but it has to be done at my place and you need at least two others that know what they are doing.
Oil Cooler Seals
Valve Cover gaskets *replacing next oil change*  Better buy a extra set to replace when you do the work
Front Seal
Installation of flaps thermostat etc.   Make sure you have ALL the right parts you will need.
Bottom Tin
Engine liner seal.   question?sign
« Reply #3 on: July 21, 2008, 10:16:20 pm »
Thanks Jack, and Matt, Matt thanks for the offer Jack is a little closer. Sorry I have to miss Katie's stories.
The engine liner seal thing is the piese that goes on the rear of the tine that keeps the exhaust heat out of the engine compartment. Bob pointed it out to me at the collingswood cruise, it's a piece of rubber around the inside lip of the engine lid... if that makes any sense.
« Reply #4 on: July 21, 2008, 10:25:32 pm »
Anybody have a preference for valve cover gaskets?
« Reply #5 on: July 21, 2008, 10:29:58 pm »
Rubber, Cork or Neoprene
Bob, Joe, John G. do you guys have a preferred day of the week If you guys can help?
*Again I'd like to do this after Englishtown*
Can this project be competed in 1 day? With 4 plus guys there?
« Reply #6 on: July 22, 2008, 06:44:07 am »
I'll be there. Like Jack says- get all the parts that you need (I would even pm him to go over the list of stuff you may need) Stock up starting now. Then we will pick a date in the fall and get to it. It might possibly be done in one day so make it a saturday in case we need the sunday. (Consult the show calendar- I want to go to pumpkin Run) And don't forget to take the weekend off! I'm not going to work on the motor if your not there! We get $70 an hour if your not there!
« Reply #7 on: July 22, 2008, 08:23:41 am »
What John said and we only  need 3 guys and yourself to watch, clean parts and learn. So you need one more person any more and we will be tripping over each other. But, if anyone wants to come and watch and learn, your mor then welcome to attend.
And MOST important You also have to bring a Jug Of Joe and  plndonut plndonut plndonut  donut donut  196 196 196
« Reply #8 on: July 22, 2008, 08:30:49 am »
Just call BugStuff and he will send the right ones.
« Reply #9 on: July 22, 2008, 09:05:23 am »
Put me on the list. I'll be there.
« Reply #10 on: July 22, 2008, 09:28:39 am »
Saturday and late fall if possible, lots going on for the next 2 months
cork works well  2CENTS
 :icon_thumright: :icon_thumright: :icon_thumright:
« Reply #11 on: July 22, 2008, 12:13:09 pm »
i forgot about the push rod tube seals. jack if possible id like to bring it to u so you can check to see if the things i listed are actually leaking before i open up my wallet. d-s d-s d-s I1t
« Reply #12 on: July 22, 2008, 12:26:59 pm »
If a hand is needed, I can help
pushrod seals? - those are cheap, but quite a bit of work to get to. Heads off and all that stuff.
« Reply #13 on: July 22, 2008, 12:27:59 pm »
wouldn't an engine seal kit include everything he needs?
« Reply #14 on: July 22, 2008, 12:37:14 pm »
Pretty much,
def not the engine compartment seal,
and maybe not the front seal......
But it still would be good to know what is leaking exactly.................
Pages: [1] 2 3 4   Go Up
