Pages: 1 [2] 3 4   Go Down
Author Topic: Garage Space Needed  (Read 20126 times)
Re: Garage Space Needed
« Reply #15 on: July 22, 2008, 12:44:38 pm »
I figure it would just save greg some time shopping around. He could get the additional seals seperate(front seal, I would replace the trans seal while you have the engine out, etc.)
« Reply #16 on: July 22, 2008, 01:03:10 pm »
But it still would be good to know what is leaking exactly.................
yea, a leak & missing tins is exactly how we started with Mikes engine..
« Reply #17 on: July 22, 2008, 01:29:30 pm »
ohhhh dont tell me that!! jack is there a smiley holding his ears?? shocked
« Reply #18 on: October 10, 2008, 09:40:44 pm »
Hey guys so my official start date for the Job is October 27 so I wanted to set up a date to do they engine pull...I hope you are all still willing to help.
Here are the possible dates, because we are doing this at Jack's Crib, I think he should have the most pull to when this actually happens.
All of these are Saturday and Sunday
8 and 9 *8th is Pumpkin Run*
15 and 16 *15th is Toys for Tots*
22 and 23
29 and 30
Dec Brrrr
6 and 7
13 and 14
Also Pat I'd like to stop by so you fix that hole behind the window  plndonut 196 plndonut 196
the following week I go back to working Weekends.
I also need your coffee preference Dunkin' Donuts or Wawa and between the tally's that's where I'll pick up the coffee and your donut of choice.
This is what needs be worked on
Pushrod Tubs/Seals
Oil Cooler Seal
Main Seal would like to put a sand seal on it I was told it keeps oil from flinging every where
All the tin work replaced if I can find it
Theromstat and hardware if I can find it
Thanks to those who volunteered to help... YOU KNOW WHO YOU ARE hell I might even order a Pizza!
Also if there is something that I should replace while the motor is out might as well do it now just let me know what it is and if it's a decent price I'll go ahead and order that too!
Thanks,
Greg
« Reply #19 on: October 11, 2008, 07:56:33 am »
22 and 23
29 and 30
Dec Brrrr ------  My garage has heat
6 and 7
13 and 14
I also need your coffee preference Dunkin' Donuts or Wawa and between the tally's that's where I'll pick up the coffee and your donut of choice.  Jug of Joe from Dunkin Donuts & Donuts
Pushrod Tubs/Seals
Oil Cooler Seal
Main Seal would like to put a sand seal on it I was told it keeps oil from flinging every where NO sand seal
Thanks,
Greg
« Reply #20 on: October 11, 2008, 09:14:58 am »
Set a date. I'll be there. Also get together with mr jack and put together a shopping list. have everything you need before the date- I've learned that the hard way.
« Reply #21 on: October 11, 2008, 10:50:59 am »
Ill be there for Photo & Video (and yes i am working on the stuff from Taylor's)
« Reply #22 on: October 11, 2008, 10:58:34 am »
Ok lets make it the 29 and 30th of Nov. so i have two solid paychecks before its time to pull the motor. Jack ill private you once i get home with the parts im going to order to seeif i missed anything, why no sand seal?
« Reply #23 on: October 11, 2008, 11:21:13 am »
not necessary
« Reply #24 on: October 11, 2008, 11:35:38 am »
Ahhh alrighty i though it would help keep the motor clean. Anybody know about these new lower cool tins that are suppose to replace the sleds? i cant find new sleds anywhere.  Unless i want a chrome dress up kit which isnt my thing.
« Reply #25 on: October 11, 2008, 01:04:50 pm »
Yea, they don't work! We tossed them out on Mikes engine they will actually increase your chances of over heating!
Stay with deflectors and lower tins as well as flaps in your fan shroud. All stuff you can pick up used at E-town
What the heck is a sled?? and don't say something to play in snow with!
« Reply #26 on: October 11, 2008, 02:00:56 pm »
Bob i think the sleds are just the slang name for the deflectors. im having trouble finding the main seal, is that the same as the main shaft seal for the trans? The main seal is the front seal right?  ???
« Reply #27 on: October 11, 2008, 04:36:39 pm »
No. The main seal is on the front of the motor (front is front , right?!)
the rear seal is called a rear trans seal and it goes in the rear of the transmission.
Write up a shopping list and try to make it to Englishtown. If you cant- ask your Dad for a favor ;D
« Reply #28 on: October 11, 2008, 05:01:46 pm »
John is right,
just think of the main seal as behind the flywheel. Weird but on a VW the flywheel end is considered the front of the motor. Anything else the flywheel is on the back, we drive some strange cars!
« Reply #29 on: October 11, 2008, 06:38:25 pm »
Took some lying but I got out of working sunday, i used my sister's wedding as a crutch. *halo flickers off*
All those gaskets and such do you get those from those tents with all the drawers and rubbermaid container? They had one of those tests at Atco and also at Flanders.
Pages: 1 [2] 3 4   Go Up
