Thanks for the video Jack! I think two things screwed me up. #1 the idiot manual says that the slot on the shaft has to parallel to the front of the engine. (In other words a 90 degree angle from the seam in the motor). In your video, you line up with the mounting bolt of the fuel pump which is off from 90 degrees. Then comes the second point- my fuel pump and distributo holes are the reverse of the one in the video- look-
So what I did was just turn the shaft to where you had it in the video and it dropped right in
So now I'll put the distributor in to make sure I'm lined up with #1 slot and I should be in the chips!
Thanks again
