Is this thing on?
Started by rockdog2877, November 07, 2008, 01:36:01 AM
Hello every body at SJVWC! I don't know if I am posting this in the right spot, but here she goes.....
         Ok well I came upon this site after along strange trip.( sorry last "dead" reference) It is a long story taudry at times but mine none the less. Ok SO this year, I had a nice chunk of refund change.....and we needed a bigger car, maybe a minivan even. SO I get to looking and happen across a bus for sale. It was like a spark of light! I never dreamed of owning one.....this goes on, so I will cut to the chase. I bought a 1974 Bus off of Ebay,the engine didn't make the ride home.. It had a 1500 beetle engine in it.  (also no firewall either!) glad that I didn't blow up, I took this a a chance to rebuild it while it sat waiting for an engine.
Witch brings me to my current position, almost there.
I can't seem to get her started. I have the bently and had some family help, But I think I am missing something small
I was hopping to have it on the road before 2009, so it leaves me with two options...
I have it towed to a shop    or have a super duper VW fan person stop by to tell me what is going wrong.
I can provide more details as needed. Oh and I am in Philly. S@Sm
Rockdog, you may want to check this first http://sjvwc.net/forums/index.php/topic,3309.0.html
Are you getting fuel to the carb?
Where are you in Philly?
Quote from: LoveBus (jack) on November 07, 2008, 07:12:07 AM
No carbs! I am on the Atkins diet!. (sorry that was bad)
I scrapped a 77 F.I. camper, I thought I could try to convert the 74 to be Fuel injected.
and fuel is getting into the engine. I just installed a brand new pump.
Your Bus has Bosch L-Jetronic Fuel Injection. You can read up on it here: http://www.type2.com/bartnik/tech1.htm and do some of the testing procedures.
It is absolutely IMPERATIVE that you fix and seal any and ALL vacuum lines & potential leaks - especially from the rubber elbow/boot that goes from the MAF to the throttle body. I have the official VW manual for my '76 Beetle that goes over all the testing proceedures for L-jet, but if you dig around you can find everything in the manual and then some online. To perform all of the tests, you'll need a volt meter, a test light/probe, a fuel pressure gauge and patience...  I1t
I gave up on L-jet (and so did previous owner) and as my sig suggests, I am converting my setup over to MegaSquirt EFI, keeping most of the original sensors and adding a few more.  I'm pretty close - it was running - then wouldn't restart since the MS brain had a defect & I sent it back for repair. I sure wish I had the time to work on it!
-Brady
yeah  I have the bently (three to be exact!) I went through the procedures. When I did it first time, it said a bad pump. New pump and the test said a bad double relay. SO , new relay and still no start.
This is my first VW (aircooled) I think I have it right, but you never know. I put in a new wire harness, but ended up with an extra wire. I spent a couple of sleepless nights thinking about reading the wire diagrams :o
I have to wire up the rear lights...and put in the axles...and get the accelerator cable in..and
Sorry, but can't offer any help with FI,
Quote from: LoveBus (jack) on November 10, 2008, 10:05:55 PM
thanks anyway...
i know things get harder with the type 4 engine aswell
Jack Kessel
Any luck with your engine starting yet?
I don't know Jack, ask Shawn
I had some non rainy weather to work on the bus. I changed the spark plugs and wires that took me a lot longer than I expected. Number2 nearly took an hour. I also added more gas to the tank. Now at 1/2.    I did get a starter to try to turn it over by my self. I didn't try to start it yet again.
I tried to find someone on craigslist to stop by and help me but no luck.
I might order the bus cover from the bus depot, I don't think it will be on the road soon.
I could stop over and check the basics out for you just to make sure they are ok but I know nothing about the FI system.
I would take any help I could get. BO** fig2 :icon_puke_l:
that what I am basically going over now, all the basics to make sure I am not missing something simple. the F.I. inspection is basically strait forward, but takes 4 hands! shocked
kickButt
If I get this running I will become a life member!
Quote from: LoveBus (jack) on December 12, 2008, 09:14:06 PM
Sounds like it may be road trip, I'll go.  burnrubber
Well I can provide grub and libations of all sorts.ask and ye shall recieve.  A running bus will be my Christmas present.
If we can get a decent day one weekend I'll let you know. Do you have any days off during the week? I'll come up and maybe Jim also.
I have off this Sunday( a rare occurance). And a fewdays later on this week.
