Pages: 1 ... 3 4 5 [6] 7   Go Down
Author Topic: ENGINE PULL REMINDER 11/29-11/30  (Read 32328 times)
Re: ENGINE PULL REMINDER 11/29-11/30
« Reply #75 on: November 28, 2008, 05:07:28 pm »
Tranny is being weird, crutching it to Jack's hopefully someone can look at it. All the gears work, but there's something wrong with the push down mechanizism for reverse. It was fine on the way to work, but leaving work today it was messed up.
« Reply #76 on: November 28, 2008, 05:54:02 pm »
I have a stock shifter if you need it...
-B
« Reply #77 on: November 28, 2008, 05:54:50 pm »
Jack Kessel
632 Tanger Ave.
Franklinville, NJ 08322
He's posted it all over this board
   @7@ Duha-aaaaa what cha you go and do that for. Now the entire VDub community will be at Jacks house for eveything from oil changes to Dinner.
 Dude you really went and done-did-it now.   :whip:
« Reply #78 on: November 28, 2008, 06:02:46 pm »
I did try a google search (of this site) before asking and it only exists in 2 places (now that I have the address & can seach for something unique in the address like 'Tangers')
Here and Here
Hardly 'all over this board'  c23
« Reply #79 on: November 28, 2008, 06:23:38 pm »
    I cant make it  m-d2 though as you know I've been planning on it.....
Pulled the radiator from my jeep yesterday, put new one in, ( 4 hr work) now one of the transmission lines is leaking real bad shocked &m&, so will have to deal with that tomorrow. I hate doing a job twice >:(
Sorry Greg!!!!!!!!! sorry. Looking forward to help doing it.
« Reply #80 on: November 28, 2008, 07:01:11 pm »
No problem Matt! Good luck with your radiator and trans! Im sure you'll be caught up when with how things went by the end of the weekend. Should be smooth sailing with these spring loaded pushrod tubes. ;D
« Reply #81 on: November 28, 2008, 07:26:53 pm »
Here and Here
Try using the site search for Tanger (no S) which is what I did the find no less than 7....that constitutes all over  777
« Reply #82 on: November 28, 2008, 07:35:53 pm »
Now now boys, play nice!   ;D
« Reply #83 on: November 28, 2008, 07:47:32 pm »
There's no flaming on this board...It's always just for fun  (love
« Reply #84 on: November 28, 2008, 08:05:49 pm »
Poof Poof Poof Poof Poof Poof Poof Poof Poof Poof Poof Poof
by any chance did you loosen up the bolts holding the shifter down ??
« Reply #85 on: November 28, 2008, 08:15:17 pm »
They were tightened down when I put the "Wobble Stick" back in. Jack seems to think that the mounting plate is 180 out of place. Will be easier to see tomorrow in the light. All the gears work, except reverse you no longer have to push down and the 1,2,3,4 gears are really close together. Once you find first you are ok.
« Reply #86 on: November 28, 2008, 08:16:50 pm »
What happened to the trigger shifter?
« Reply #87 on: November 28, 2008, 08:35:02 pm »
i was pulling out of work, and it wouldn't go into second, it kept trying to go into reverse. So I crutched it home w/o a 2nd gear shifter seemed Wobbly, put in the stock shifter and that was even worse. Jack thinks that the shifter mounting plate is 180 degrees off.  It will be a lot easier to see tomorrow in the daylight.
« Reply #88 on: December 01, 2008, 10:28:44 pm »
Had several decent size puddles under my car after the meeting, I'm a little worried. The push rod tubes were clean with no oil on them. I'm just hoping that the engine is sweating off the oil and grime.  :'(
Time to order the 1776 long block.
« Reply #89 on: December 02, 2008, 09:17:46 am »
I have to ask the dumb question... Were the puddles there before you got there?
Pages: 1 ... 3 4 5 [6] 7   Go Up
