Soooo
If you all remmember in the last episode I cut the back of the glove box so I may have access to the wire plugs. Also, as you can see from this next shot, on the back of the stereo there is a mounting screw hole. I bent a small piece of aluminum around a small nail punch and drilled a hole in the end of it. I then screwed the the aluminum piece to the back of the unit and then threaded a cable tie through it.
This cable tie will then go around the center piece of the back of the glove box, thus preventing it from sliding in and out of the glove box
Next step was to work on the face plate. I took a piece of cardboard and after trimming it with scissors for about 20 minutes, got it to fit into the box where I needed it. I didn't cut out the area for the stereo just yet. If I did, the cardboard would bend or tear easily.
So I used the full plate to cut out a piece of rigid board. Only thing I had around was some old peg board material. I didn't want to use plywood because it's too thick. You would have to taper in the sides in order for it to sit in the box evenly.
After cutting the basic shape of the plate, I then continued with the scissors cutting the template and then transfered the outline of the stereo onto the peg board. After the cutting was done, I just needed to keep trimming and fitting until the face plate fit in the way I wanted it to.
When I was happy with the face plate fit, it came time to finish it. Luckily the last time I did upholestry work on weezer, I save all my scrap vinyl. I had a nice piece that was large enough so I laid the vinyl down on a clean board, placed the face plate down on the fabric and traced it
Got out my handy dandy scissors and cut around the fabric.
Now I have glued the fabric onto the face plate but I need to stop here so I can catch up on my photos.
Tommorrow I'll finish this up and post my finished photos.
