Well yes i finally did get the stereo in and working. Not terribly thrilled with the look but it'll do till I get another idea on how to screw it up more.
Here is a shot of my fuse box. You can see the two piggyback pick ups I put on the fuse box for the electric hook up. What you maynot realize from this picture is that I have the wrong fuse in the wrong holder. White fuses are 8 amp, red fuses are 16. There should only be one white fuse inbetween the two reds. Not 2 like I have. This is the fuse box. Mine is upside down. You can see that the 3rd fuse from the right feeds the horn, radio and a bunch of other stuff
Mine (albiet upside down) has this fuse in the 4th position. So remmember folks- always check your manual and your fuse box. Don't let stupid happen to you!
After the wiring crap was done, I reinstalled the glove box. this shot is from underneath
and then this is the unit in the glove box
As I said I'm not totally thrilled and I have to clean up the area a little but it'll do for now. And heck, I can always keep the door closed.
Now I just have to figure out the speakers s#r s#r s#r
