Author Topic: Testing Tach  (Read 3084 times)
Testing Tach
« on: January 28, 2009, 12:24:06 am »
To test the tach, I should be able attach the hot wire to the coil *on the side that connects to the choke and the pressure valve* attach the other wire to the other side of the coil and then attach the ground to something attached to the frame and it should work right?!
Hopefully it won't be raining I really want to try it out tomorow!!! c P#3 P#3 P#3
It's a lot smaller than I imagined it would be, I might be able to fit 3 gauges on the one side.  !5!
