Pages: 1 [2]   Go Down
Author Topic: Look Ma! No Wires!  (Read 18660 times)
Re: Look Ma! No Wires!
« Reply #15 on: March 12, 2009, 08:29:24 am »
here is your Wikipedia check list...
http://en.wikipedia.org/wiki/Dieseling
« Reply #16 on: March 12, 2009, 08:50:00 am »
Great article Rocky. That needs to go into the archives!
Guess the Meanie's getting that overhaul I knew was inevitable.
« Reply #17 on: March 12, 2009, 11:35:52 am »
If you decide to pull the heads, check the deck height ( space between the top of the piston and top of the cylinder ) also if possible cc the heads. I've got the stuff to do both so if you need help let me know. The reason I mention this is I'd bet that engine was built with a super high compression ratio and if so that will just add to the problem.  2CENTS
« Reply #18 on: March 12, 2009, 01:41:58 pm »
Don't worry... If I open it up, it's getting done right. I'll be calling
Pages: 1 [2]   Go Up
