Author Topic: ballast resistor  (Read 2656 times)
pellt
ballast resistor
« on: June 06, 2009, 12:05:35 pm »
 sjvwc.ico Any info on Empi Accu-fire? I have one in my 009 with a MSD SS Blaster coil and without a resistor, the coil and dist get hot, with a 1.5 ohm resistor the resistor gets REAL hot, does the bosch blue coil with internal resistor have 3 ohms resistance? The pickup instructions say use a coil that is ok for points (1.5 to 3 ohms) ????? vwlogo
Re: ballast resistor
« Reply #1 on: June 07, 2009, 09:03:50 pm »
Pertronix makes a 1.5 & a 3 ohm coil.
Pertronix FlameThrower Coil
pellt
« Reply #2 on: June 08, 2009, 09:50:51 am »
Thanks, i ordered one should be here WED. vwlogo
