Author Topic: Now that the flange is fixed....  (Read 3220 times)
marcr1
« on: June 17, 2009, 12:54:31 pm »
thanks again for all the help with the flange.  and yes a piece was broken off but no telling how long ago, so i will just cross my fingers and hope for the best.
   my next question is a carb issue.    i have 34/3  and the larger screw (bypass) is always moving out of adjustment.
    i swapped it with another one and it still moves after a few miles.
         Does anyone have a trick to keep it from moving .
Re: Now that the flange is fixed....
« Reply #1 on: June 17, 2009, 01:05:19 pm »
Does it have the rubber O ring around it ?
marcr1
« Reply #2 on: June 17, 2009, 01:17:51 pm »
yes it does and it seems to be in good shape.it looks like it sticks out just past the threads of the screws.
« Reply #3 on: June 17, 2009, 02:02:34 pm »
Haven't looked at one in a while but I think it sits in a groove right about where the threads end. Stupid idea but is it possible the threads are stripped ? I've got one on one of my cars also and its usually very tight.
marcr1
« Reply #4 on: June 17, 2009, 02:12:25 pm »
if it is stripped it would be on the carb side. this is the 2nd bypasss screw i tried.  and they both slip.
« Reply #5 on: June 17, 2009, 03:08:52 pm »
Replace the O ring ring seal and it won't move anymore. I think I have some.
marcr1
« Reply #6 on: June 17, 2009, 03:42:59 pm »
thanks for the offer but you are about 2 hours away     let me see if i can find one here
