0 Members and 127 Guests are viewing this topic.
peltzer71
Quote from: JackWagen on May 22, 2011, 01:31:30 PM
Chris, how did you get the tape job so good on your hood, come and do mine. whistleegi please.
  clap2-*  Thanks Jack.  You have to use the cheap white tape and rush because it's going to rain!  lol.
I just run the tape across the hard radius corners and use a straight razor blade to cut the tape to the radius.  I wish I had a garage to play in I love to paint things.
Quote from: Evil-Tunes on May 22, 2011, 04:11:36 PM
I can't find out how big A 200mm flywheel actually is? &(rage_
200mm  #@rofl3
200 millimeters = 7.87401575 inches.
Now i'm confused it looks like It has allready been done I think?
Could the 36er have a 200mm fly wheel on it allready? }dunn--
Yes I have the bushing and yes going to 12v
clap2-*
Yes its done already  **^bana0 lucky you
My hand shakes to much, I'd end up cutting my finger off and not the tape.. %$oldcit
Quote from: Baha (Shawn) on May 22, 2011, 06:20:16 PM
200mm  #@rofl3
Hardy Har Har  Smart ?/moon2.. LOL
I finally found out that a 180mm flywheel = 10 3/4" and 200mm flywheel = 10 13/16"
a flywheel is referred to 180 & 200mm because its the size of the clutch not the flywheel.
Quote from: JackWagen on May 22, 2011, 08:44:57 PM
Jack stole my thunder...  Yup, you measure the machined surface
Installed the tire bracket on the front I don't have to cuddle with the tire at night. Still need to put the artwork on the tire cover! SJVWCC  whistleegi
Found out that the Split trany was indexed for the 180mm flywheel only. @%soapbox
I had a hell of a time trying to get the motor in by Myself.
So I grabbed a Drill and 3" x 2" drum sander and went to town.
I prob. took off 1/16 or more at the bolt holes and at the starter.
Found out that when you hit a steel bolt that causes a spark the trany shavings will flash.
INSTANT fire starter.
@campfiresmiley Water didn't help the problem and I wasn't about to use the air gun untill it was out!  1!bomb
I did a very stupid thing by Hammering a 1 1/8 scoket on the crank bolt it was the only thing I had that was Close.
All that is left is the horn and some fuel line and hooking up the voltreg and coil.
Now I'm woundering if I should have changed out the throw out bearing?
This is the new pressure plate I put in. Will these work together? :confused04:;
 &(rage_ Pulled the Motor once again and have to wait for a new Pressure Plate. bawlin)0
peltzer71
 clap2-* Installed a new Empi shifter in the bug.   Like a new car.  No guessing which gear I'm in.  I can actually downshift now.
  FYI... Glen had the motor out of his Buggy faster than I installed the new shifter!
Glenn, I was looking for a clutch for you in the garage but turned out to be 3 of the new type I have.
While I was looking for a clutch I FOUND MY CAMP STOVE 1banghead7&  it was behind my creeper.
Quote from: JackWagen on May 25, 2011, 07:34:45 PM
Oh thank god!!! You were so sad at GGB7 I was going to give you mine just to make you feel better
BTW Took the Syncro out for a drive this evening. Think I'll take it to work tomorrow
Fahrvergnugen
