0 Members and 35 Guests are viewing this topic.
While waiting for the Pressure plate to get here I put the two back motor mounts in.
I think I found the chattering I was getting while starting  in first gear.
Mounted the Voltage Regulator on the Generator
Found flags for the MugBug for Clayton parade.
My flags are still in Mildred from last year!
Quote from: Beetleboi -Greg- on May 26, 2011, 07:01:02 PM
Everything's still in Mildred from last year!!!   &^rofl &^rofl
went on my first dive out side of the hood, went from manayunk to the airport for work.
no parts fell off, and no flames! (no 76 either)
Installed new speedometer cable today. Old one went kaput.
Quote from: rockdog2877 on May 26, 2011, 08:26:37 PM
**^bana0
Took the Syncro to work. Man, I love the way it rides
Put the pressure plate,clutch, and throw out bearing on and put the motor back in the buggy. :jump4jo": **^bana0 :jump4jo": **^bana0
Rich stopped buy and helped with the wiring. Thanks Rich.  Trying to get the motor started I got the wires switched on the coil and Oil switch  ?/banghea?/ I think I fried the sending unit  bawlin)0
The motor Started   2@@cool. I guess Murphy was sitting out side the door when I went to adjust The clutch cable It broke. &(rage_
Not sure If the buggy will make It now. I'm going to see if I can Rig It some how because I'm running out of time.
I hope Polarizing the Generator works because the white light is on. }dunn--
Glen,
Panty hose and duct tape...works every time.
-Celly
I ain't touching Celly's comment :)
Quote from: ykuday on May 26, 2011, 10:59:54 PM
Glen,
-Celly
I decided to go A different route Celly. I did think about it tho   &$hmmthin_+
The Fix.... I grabbed the Spare Clutch Cable. Thanks (Shawn/Tyler) From the Bus & Hit the hardware store.
Now I have a New/Old problem   16rooler  The Dam thing Chatters and Hops Like a bi ch   Starting off in first gear.
I thought the new engine mounts would have solved it. It would do it before but not this bad....
Do you have a nice bend in the preload tube?
Did you try pushing up and down on the tail pipes to see if the front mount was bad?
Eeeek...
Cable clips in a "butt-splice" might slip. A loop in each cable would be better but, any port in a storm
weld the cable with that set up on it so it wont slip
