0 Members and 163 Guests are viewing this topic.
Guys, Never park your car for a long time with the E-Brake on, put it in gear or chock the wheels. Even over the winter the drums can rust to the brakes.
put it in nuetral and put it on jackstands
Quote from: Evil-Tunes on June 11, 2011, 08:39:47 PM
Peltzer and I put a new Pass. brake caliper on the bus. I knocked the Rev. lockout off the P.O.S. EMPI shifter so I had the neighbor weld it back together and strengthend it up a bit. OMG I washed the bus too.  -eyescan.=  Rdy for June Bug Classic XXIV now.  (*speeder
Brakes Still SQUEAL  &(rage_ bawlin)0
Have to get the rotor Cut........
is the rotor scored? Are the pads thick enough? If not, just run them for a few days until they get used to each other
Are your anti squeal shims in place? Also you may need to use some anti squeal silicon with the shims.
Guys, this is a continuation of the problem I had with it. Cold the wheel spins free, but after using it the brakes get tight. Come back from a drive and put it on a jack an its tough to spin the wheel. The next morning, it spins freely. He's replaced the lines, and now the caliper
Quote from: Baha (Shawn) on June 13, 2011, 09:03:52 AM
Thanks Shawn for the explanation.
Could it have something to do with the master cylinder?
It was weird comming back from June Bug Show. Would only squeal when I turned the wheel. Stopped at a store for a few min. Then would only squeal going straight and stop when turning?
So, pass. side only, Glen?
replaced lines but did you replace the hose?
master Cyl. only if there isn't enough free-play in peddle
would have to see it in person otherwise just guess all day long
MC is my guess too.......
   By the way, I never put the emergency brake on, so was surprised wheels were locked  }dunn--
Quote from: JackWagen on June 13, 2011, 02:10:48 PM
Here I go answering for Glen again... By lines I meant soft lines (hoses)
Quote from: 6T5 square on June 12, 2011, 07:54:41 PM
put it in nuetral and put it on Jack stands
I prefer Shawn stands but I guess if there good enough for Jack....
Finally !!!  Took the 67 Bug over to the paint shop !  :jump4jo":
Have to go back on Sat to check on progress.  clap2-*
Will keep you posted  7&7sun
Congrats Yuma-
remmember- pictures or it didnt happen
