0 Members and 128 Guests are viewing this topic.
Nice Trick Shawn I will have to use that.   2@@cool
I just tucked them there to get them out of the way. No where close to fireing her up yet. Q3surrender.gif
Making the Meanie shine for Dubs on the Boards
Wow... you could eat off that engine!  clap2-*
While I'm waiting for my engine I took advantage of the empty engine compartment and ran a new main wiring harness from the fuse panel to the back. Hooked up the battery and success. All lights, wipers, gauges etc worked the first time.   :jump4jo": :jump4jo":
Backup lights were a challenge. Couldn't find the d--m sending unit.  &(rage_
Look for the sending unit (switch) on the front of the tranny nose,
if it there, i had the same problem.
Quote from: kvbug on September 05, 2011, 03:53:38 PM
Only if you lived in certain areas in Pa....
Quote from: buglvw (Howard) on September 05, 2011, 04:07:04 PM
find the switch?  a little tricky....
Ya, the little sucker was hidden up in the very front of the trans.  &rant((
Now that you found IT, make sure that it is not shorted
out, or shorted to ground  &(rage_
Cleaned the Garage to get a little room around PinknGruvin... byeby.,
Still more work to do in there like putting chit away.  :confused04:;
The last time I cleaned it was  when I patched some of the floor and put...... Jen and Glen 2001 in the Patch  #@rofl3
Added 6 new florescent lights 5 inside 1 outside & Upgraded to T8 bulbs w/electric start good to 0 deg F
Should be good in the barn no more blinking lights in the cold :jump4jo":
Matt, which parts of PA might those be where the engines are so clean you could eat off them?
Glenn PinknGruvin is looking good in that well lit , clean space   &^beer&    Can't wait to see Jen taking her for her inaugural run!
 2@@cool you have more room then the GarageMahal does now. #@rofl3 #@rofl3
Quote from: JackWagen   (jack) on September 07, 2011, 08:08:55 AM
Nuh-uh
Quote from: JackWagen   (jack) on September 07, 2011, 01:47:58 PM
Opsss, you been cleaning clap2-*
Won't be roomy for long....
The Bay Window towbar arrived today  **^bana0
Time to bring home the Champagne!
