0 Members and 11 Guests are viewing this topic.
71vert
Here's when they started it up!
I think How's Thumbs up says it all...  Look how happy he is!!
Ahhhh the sweet smell of exhaust! The pitt crew right before the victory lap around the block!!
**woohoo {}congrats 22CLOUD9)
Just a few minor tweaks and "Sunny" (as my 8 y/o calls it)  will be out and about joy riding with me!   5%5mexwave
Great job Bob & Son VW Repair.
did it make it around the block #@rofl3
 ((thumpup    Great job,  guys!   I'm sure "Sunny" is purring like a kitten   thumpup)-
Took off the Auto Trans lines at the Trans to see if pump was pumping.   :jump4jo":
It is pumping Oh Well back to the drawing board.... #banghead
Windshield is in -  :)   did a bunch of stuff, tightended the wiper motor mounting nut, (real loose) lubed the wiper pivots, now it goes from sloooow to slow. graphite the locks, lubed up hood latch.
I think my carb (Solex) may need a rebuild. I spray gumout on where the throttle is and it revs up. Throttle bushings?
Might be if the over spray didn't get sucked in someplace else like the base of the carb.
Quote from: JackWagen   (jack) on November 14, 2011, 06:58:53 PM
Or the intake boots where the center and side sections come together!
Thx guys. Good wintertime project. I rebuilt one on my '67 when I was young, stupid, and didn't have a pot to piss in. Now I'm old, full of wisdom, and have a shirt that certifies I don't have a pot to piss in....
I didn't do chit, but a bunch of great guys got Irene running! Cannot wait to drive her again.
As you know by some previous posts we finally got our engine from Savich's Auto. A couple things we found out while installing the engine that you  %$oldcit guys probably know, but this was our first engine install.
The old single port engine had nuts and bolts and nuts and studs holding the engine to the trans. Our new dual port engine had a threaded insert in the upper driver side mounting hole. The problem is the old bolt locked into the trans housing so the bolt wouldn't turn when you put on the nut from the engine side.
So Tim got a longer bolt and slid a nut a little larger then the bolt onto the bolt. The nut then seated into the trans housing and allowed us to tighten the bolt to the trans.
Also, we didn,t know you had to line up the accelerator tubes between the body and the engine. The cable was binding until we figured that out.
We had to take the GT muffler off to get the engine in because we couldn't get the right angle on the engine to slide it in. After we got the engine in the exhaust pipes hit the apron. Ramon told us about the spacer you could put between the body and frame in the rear. But he said be carefull you don't break the bolts trying to get them off. Well lets just say one out of two ain't bad  &(rage_. Anyway they worked great and now we have nice space between the apron and the exhaust pipes.  **^bana0
The next problem was the throttle linkage. The new engine has a weber 2 barrel progressive carb and the old engine was a stock single carb. The linkage off the carb was too  high comparted to the tube coming thru the fan shroud which caused the throttle cable to bind at the top of the tube  #banghead. So we "fabricated" new linkage using some aluminum rod. This allowed the cable to slide straight into the tube without touching the sides. So far it seems to be working.
Savich adjusted the valves after we put about 10 miles on it because it was making noise. We put another 70 or so miles on it and changed the old and external filter.
Sunny didn,t want to leave Ruby after spending about three months with her. So I litterly had to drag (tow) him home. He's in my neighbors garage sulking. Hopefully he will see her Sunday on the Frosty Cruise. &^beer&
71vert
Yes, Ruby does miss Sunny.  But the Camaro has been weeping itself to sleep at night...  Who knew?     :confused04:;
LOL!
Howard,  Sunny sure has been through the wringer...  Glad he's in nearly tip top shape now. He'll adjust to his new home, and I'm sure as long as he still sees Ruby on occasion he'll be a happy camper   =wink=
Good job on all those "adjustments"...
Tim
#1543
Hi Everyone, didn't now where to post this but :jump4jo": this was the best spot...
I'm Tim and my wife and i split our sites. I know she posts alot. She owns Ruby, and I am the happy mechanic.
She never post about the work, but I will!
Hi Tim,  yes please post the work that you do...  we don't want Heather taking all the credit for Ruby.. lol        Although she does look fabulous in her...
"The Happy Mechanic"....    ((thumpup
