0 Members and 7 Guests are viewing this topic.
Glad to see you on Tim. Hummmm, Heather said she did all the work on the car. (o;
71vert
Quote from: JackWagen   (jack) on November 16, 2011, 01:40:36 PM
Hey hey hey now!   I said I did all the washing of the car and that is the IMPORTANT work!!  2@@cool
QuoteI'm Tim and my wife and i split our sites. I know she posts alot
[gunfiring\  Does this mean I should behave?   17gif Because I probably won't...  ?/moon2..
And Tim, it's Ruby...not Rudy!  (of course you may have just named the SS)   #@rofl3  **blows kisses**
I didn't want to correct The Happy Mechanic on the name of the car.. lol
Behave?!    WHY would you do that?    &^rofl
71vert
Quote from: kvbug  (Karen) on November 16, 2011, 05:06:13 PM
&^rofl #@rofl3
I wouldn't behave...There's no fun in that!
I do like "The Happy Mechanic"  Maybe a future t-shirt with that printed on it and pics of peanut M&M's?? Huuuummmmmmm.....
50split(paul)
spent all yesterday in the pole barn working on the 52. pulled engine to install new intake manifold. need to reset the throttle ring clearance via the thermostst.
the noise i heard was throttle ring hitting the fan and not bearings in the generator like i thought. new accelerator cable, new roller pedal,grease front beam and pedal assembly.
waiting on generator pulley hub and pulley plate. piston rings, new tranny oil and engine oil .......should be done by spring.
Tim
Does that roller pedal increase the cable travel at the Carb? Had a problem with my Dads car, and was wondering if that might help?
Quote from: Nuebug on November 17, 2011, 11:02:14 PM
what year is your dad's car?
The "Z" shaped linkage under the pedal may be loose. That is usually the cause of lack of cable movement! You can get a rebuild kit here:
http://www.airheadparts.com/vintage-vw-parts/pedal-assembly-parts
Tim
A 71 don't have the Z linkage but the pedal can bend and the arm with the roller on it can bend or you may just have the wrong cable.
Try undoing the cable at the barrel nut at the carb and see if you can pull it past the barrel nut, if it does the cable is to long.
If memory serves me right, I think a '71 has a small roller under the pedal. The pedal is supposed to follow the roller. The pedal may not be making contact on the small roller?
This may help?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-798-507-F
Tim
#1559
See this stuff Dad, Guess You will have to come back, so we can look into this stuff! *)copcar. +=ourlogo+=
