0 Members and 53 Guests are viewing this topic.
Work continued today on Glen's Buggy. Did a lot of disassembling! Link to some picts:  https://picasaweb.google.com/109018163742863592767/NigelProject2011?authkey=Gv1sRgCO6f8ZPF_fOgzgE#5714602408071880818 Where does all that go when the trans gets installed? I sure hope I can remember long enough %$oldcit
Quote from: Bob(Herbie) on February 16, 2012, 05:25:34 PM
Work continued today on Glen's Buggy. Did a lot of disassembling! Link to some picts: https://picasaweb.google.com/109018163742863592767/NigelProject2011002?authkey=Gv1sRgCKi2zd7-qc_k2wE#5709863870811401890  &$hmmthin_+ Where does all that go when the trans gets installed? I sure hope I can remember long enough %$oldcit
clap2-* clap2-* clap2-* clap2-*  Lookin Good!!
It's nice that the panels can be unscrewed like that to get access.
Pat got the welding done yesterday and I got the gas tank back in, ground the welds down.
Now all that has to be done is his radio hooked up and Shawn (the radio Guru) said he would do that thumpup)-
I used OEM MugBug paint!! thumpup)-
Drove to the car show in a Cabriolet... came home in a tow truck.
I'm really sorry  whistleegi if you had to work yesterday and today but I was thinkin about you when I took TheStrap out for a ride, it's so nice out.
My daughter is up from FL for the week and we will be going for a ride again after lunch (*speeder
Keep the economy going for us retired folks thumpup)-  &^rofl #@rofl3
We're trying Jack,  we're trying...    &(rage_
#@rofl3
Put on new battery terminals hoping maybe they were shot, nope. Still not holding chargee. I feel like I'm moving in circles. Was hoping the battery was going to be dead when I got in to start the car... it wasnt . Hoping for a short. Can't test amps without a multimeter. When jumping the car battery pulls power right away from other car, then the power drops at a rate of .002 volts every second. Alternator works at the parts store, I just don't think it works in my car. I know belts were moved when the ac was deleted but that should affect the speed or direction the alternator spins. The output for the alt is the same (drops) as the battery. With the toyota hooked up to the cabriolet the voltage is at its highest at 13.5ish. I'm done with the cabriolet for today... I'm going to patch the busses exhaust leak so it'll be ready for inspection Saturday.
Fixed it... put a jumper from the exciter port to the battery. (Bashes self in face)
Worked on Glen's buggy today. Tranny is in! Had some trouble with the tranny. Had to change the nose cone because some one cut and welded the front mount and modified the split tranny nose cone. I had to use a bus nose cone and '62 front mount with the small rubber to make it line up for the shift rod. Good thing I keep all that junk (stuff)! Adjusted the rear brakes. I plan to work on the engine tomorrow. Too tired for picts, take some tommorow 40sleep3
Also, I almost forgot. I installed the dual voice cone Retro Sound speaker in Herby today. It sounds great. I can even hear sterooooo **^bana0 :jump4jo": thumpup)-
Quote from: Beetleboi -Greg- on February 23, 2012, 04:55:29 PM
I seem to remember that suggestion being levied at the very FIRST sign of this trouble  ?/banghea?/
