Funny when people get that notion into their heads isn't it??   #@rofl3
Quote from: Baha (Shawn) on June 14, 2012, 10:47:51 PM
Gave Joe T the 50 cent tour of the TMG  and 4-1-1 on the Champagnes Engine. While showing him how the retainer wires work to hold the pushrod tubes in, I discovered there were no retainer wires holding the pushrod tubes in
#banghead
Apparently the PO thought he was smarter than the team of German Engineers who designed the Type 4 engine.  ?/banghea?/
H
I can understand how the PO ditched them as they are a real PIA to put in I imagine it could run without them but let's do it right and get em. It's way gooder .
Just unsuccessfully played with SuperGlue and inhaled this crap and got it on my fingers and rear shelf.  #banghead After using double sided Velcro, SuperGlue and 3M adhesive, I just figured out why after a few hours of trying to have this stupid third brake light not adhere to the glass what the problem is.  +=mystery)?
JACKWAGEN!
Simple, he used his secret "Lets get folks pissed off" spray on the ends when he hooked this POS up.  So, club members, beware. -eyescan.=
I'm thinking that he used it on Sophia when it took hours to get the brakes done, or Tylers engine when we had to drop the engine four times.   #@rofl3
I knew it was only a mater of time before someone caught on to me.
vwnutt
Worked until midnight last night on the Jetta.
I have had a power steering belt squeal for a few weeks now.
The PO had installed a solid rear motor mount that I removed 1st thing when I got the car.  #banghead
Unfortunately the vibration and lack of proper torque and lock-tite caused the power steering pump bracket bolts to loosen and one to fall out. bawlin)0
If I hadn't fixed it I dont know what would of happened if it fell off!
To do a PS belt you need to remove the ac & water pump belt. Turns out the AC compressor lost a bolt too. No wonder it made a racket!
Luckily I had a few bolts in my stash but I had to remove everything even the mounting brackets, re-tapp the threads and put it all back together.
It runs great now!  **^bana0
Just goes to show, even the water-cooled guys sometimes thing they are smarter than German engineers!
How many Marks are there?!?!
Was basically told I have an expensive hobby, and I should consider finding a better paying job.   ?/banghea?/
Quote from: Beetleboi -Greg- on June 20, 2012, 09:17:07 PM
WHO TOLD YOU THAT?
Greg, whoever told you that needs to come to my house. Oh no, you got me started..     &rant(( They think YOU have an expensive hobby, I'll let them look at the bills for my husbands race truck!   &(rage_   We could have bought a second home (seriously!!) with what he has into that thing,  so tell them to  8*gaged  because your hobby is a cheap one!!!!!!
Ok, I'm off the    {_^soap  now...    #@rofl3
They must be talking about the Brass5 I guess. :confused04:;
BTW, Beet, I'll bring the donated sax to the picnic. **^bana0
Installed a throttle to trans cable in Irene. Much easier than the bus.
If you need help with the water hose let me know.
Yes, if you need help, let me know and I'll ask JackWagen  ?/moon2..
I forgot I have a new Manager, ask Muggy to ask me if you need help.
