0 Members and 19 Guests are viewing this topic.
Quote from: VWPANZER1 on August 20, 2012, 10:23:49 PM
  Looks like the cam froze and the crank kept going. Your going to have to do some carefully measuring and cleaning to determine what parts are re-usable.
Thanks for the insight Joe. Too the "untrained" eye things look pretty good. But I'll have to get you experts to give it the once over before it's put back together.[/b]  (hail-
Howard, I have two complete blocks in my backyard, Don't know if they are 1500 or 1600. But if you wanna look, you can have anything that  would help.  Dave
I have a few less "iffy" candidates you're welcome to pick from
picked up a 77. cant believe the overall condition of the car. everything works as it should . . . (besides the motor) it is fuel injected but plan on getting rid of that. has anyone ever converted one to a carb?
Time to evolve . Don't throw it away because you don't understand it...
Learn it... Master it.  *8emperor
I Like the late model flat window, Good luck with it.  Now the big question, Stock or modified?
the plan is complete stock besides the rims. i would keep the fuel injected but im 99% sure the motor is locked up. floor pans have some iffy spots nothing bigger then quater sized. battery spot is perfect. bottom of heater channels look great. but where the running board bolts too has a few bad spots that i will just patch. i kinda like the silver too, looks like the original color.
Found this red thing in my garage today. Found a key and turned it it's a MugBug!!!  **^bana0
Dusted her off,  put a new SJVWC sticker in the back window, and checked the oil   which by the way was perfect in level and clarity.  thumpup)-   Good girl.....    love__
Quote from: MugMan (Rich) on September 19, 2012, 04:50:42 PM
And I thought you moved out of state :confused04:;
Quote from: Ant on September 17, 2012, 11:23:34 PM
If the F.I. is running it's better performance then a Carb.
But if your set on converting it to a Carb, it will be a much cleaner install.
Just did a 1978, converted it to a Weber 32/36 clean install with lots of available powerband..
My Personal Opinion is the Carb Setup looks cleaner, it's simpler to fix, and more eye appearing..
Took Sophia to her first official car show today.
Helped Peltzer put a New throttle cable in today.  &^rofl  He all most made to the house when It went.  bawlin)0
He also stole a roof rack?  &(rage_  Looks good with his new fenders and Rims. &^beer&
Yooooohhhh. The Rat's sportin some fatties... Nice
