0 Members and 9 Guests are viewing this topic.
Cleaned the ice and snow off of them? Yuck
QuoteMy name is Jim and live in Bellmawr.
I wish I could take some pics, but I've been getting home after it gets dark.
I'll post some next weekend.  Thanks again.
Hey we're almost neighbors, I'm in Audubon
Dagerm
Vacuumed the broken glass out of the drivers door. Started stripping paint of the door. I got most of it off and decided it would be easier if I took the door off. So I tried the air hammer and one hinge pin moved about a millimeter. I took the caps off and sprayed PB blaster in the holes. It didn't even run out the bottom of the hinge....just sat there in a puddle laughing at me 777. I checked back in a couple of hours and it sort of went down the hinge. So I have been spraying the hole full of PB before I leave for work,when I get home from work and before I go to bed. Who knows how may times I wil have to do that @7@. The first time I spary and the PB runs out I will try the air hammer again.
keep going at it with the air hammer. Sometimes it takes more than a few minutes of non stop running in order to get them out. A few millimeters is a good sign. But they will not just "pop" out.
Quotesprayed PB blaster in the holes
PB is your friend, just give it time it will work
Took me 3 days to get the right upper pin out  &m&
Used PB & large C-clamp to get it started, then
the air hammer.
Check samba, on how the C-clamp is used for
door pin removal.  It works  BO**
Yuma    ( Sonny )
Dagerm
Thanks. I'll check Samba for the C clamp trick. I had hoped the pins would come out fairly easy, but have resigned myself to the fact they have to be driven out a little at a time. Never used PB before, but have heard nothing but good about it....still nothing coming out the bottom of the hinge...but the puddle is going down faster....PROGRESS!!! :icon_cheers:
Drove it home from Philly. It's not running good at all. Losing power, stalling, flat spots... I hate tune ups. Maybe it can wait till the end of the season. Anybody ever use a digital timing light? I think I saw one at harbor freight.
Took it a blanket and some hot cocoa this morning and promised it I would get it inside by the weekend
Called and made appt for front end align for the Golf
Awaiting CIP1 package arrival today with new shift coupler and assorted new hoses so the GlowBug doesn't have more gas smell than me after eating a Holiday 3 bean cassarole  I1t and also may have all 4 gears  drive&&
jive512
I finally got a chance to take some pics.  A little embarrassing, but I have to start somewhere.
http://roseb.net/zenphoto/72-vw/]
Put up Christmas lights and a tree in the bus.
Dagerm
No pics....there is no tree.. @3#
I'm still working on the hinge pins. Sprayed PB in the holes everyday, sometimes twice a day. Broke out the air hammer again today and the bottom pins moved. Less luck with top ones, but some movement. I turned on the compressor and let it build up to pressure, then turned it off and hammered until I ran out of pressure, turned compressor back on and repeated on next pin. Rusty liquid is coming out of the joints where the two hinges go together. I think this week I will spray PB before I go to work and use the air hammer everyday when I get home.
Slow going but I'm making progress. When I get everything put back together I think i wil take the pins out once a year....just because. :icon_cool:
