0 Members and 328 Guests are viewing this topic.
   Just got power 20 minutes ago. Wow, back from the 17th century.
Washed the Passat & the Golf, Beetle stayed in the Garage
I spent some time on the Rat Rod and fixed the Broken Valve Spring.
It all most fell part Easy and in 3 peices
I knew the trick about Getting the keepers loose and out
Compressed the spring wrong the First time. The fingers  of the compressor were in the way and I noticed that one arm was longer than the other.
Found out Why! When you do it correct. 11&*
Is there a Trick to get them back in???? After A hour I got Close.....
20 min later Success!!
Did a Quick setting of the Gap, checked the others and checked the Points.
Took her out for a Drive  too charge the battery. skid))  Next on to the SQ Back................. unbrelola
I cleaned Happy Trails for the trip to Cape May CH this morning.
Put a gap between the petronics and the roller... Apparently there was suppose to be one Set it to matchbox thickness till I find my feeler gauges. Pulled the bus out onto the road (first time since break down) runs real smooth... Just doesn't want to start. Thinking carb is leaking fuel into cylinders? Does this happen? I have most of my tune up stuff, just gotta get over my confidence issue. Bus runs better than when I went to grannies... Aside from the very poor starting.
Purchased a buzzer that will connect to the oil pressure sensor since my light doesn't work. Wiring nightmare.
QuoteJust doesn't want to start. Thinking carb is leaking fuel into cylinders? Does this happen?
It can happen.
Beet Get Bob Herbie to rebuild your carb in Mildred skid))
Went to Vanagon Land to have Roof Struts installed on Happy Trails and OMG it is sooooo easy to put the roof up now
it almost pulls me up with it   unbrelola   -rofl\   I highly recommend this upgrade to to everyone... 11&*
Now I put Shawn out of a job because I use to have him put the roof up for me 11&*
With everything Jay does it looked so easy to do, he had the job done in less then half an hour  +hug
I don't have any trouble putting my roof up... What's all the fuss about  4thinking6
DreamWeaver J@Y:~}
Dang stubborn Jack Arst, I've been trying to beg him to install these PopTop Roof Assist Struts for about a year now.  idea\
Lucky I had them in stock.
Glade your enjoying them Buddy..  11&*
Life's G@@D @ Vanagon Land  =bananachaplin+= .
Believe that and I'll gladly sell you some swamp land in the Everglades.  &^rofl
Quote from: Baha (Shawn) on July 24, 2015, 11:02:52 PM
mo-on
I'm next, the two solar panels add like 50 pounds.
Quick Brake line Swap and BleedFlag*
The Buggy was Scary !!! Hitting the Brakes would make a Quick left Jerk on the steering wheel.
   abike- Straight as a Arrow Now.
VVV See Video Below VVV
