0 Members and 20 Guests are viewing this topic.
Removed engine, installed new front engine seal, installed new clutch (old one was soaked in oil), reinstalled engine, replaced gas filter ( next to transmission- where it belongs) replaced fuel lines from front to back, installed new, thicker cotter pin in fuel reserve lever. Still have to adjust brakes and tune up.
Ok- so it took more than one day.
Gunterwagen (Nick C.)
Good idea on moving the fuel filter. Did you get the fuel filter bracket that mounts to the transmission? It may be a pain in the behind to change the fuel filter, but it?s safer. A little experience with that.
More than one day? you need to get up at baker's hours!  s=un
Nice on replacing the fuel lines front to back, very few do that,... including myself. Will put that on my list
Hope the tune up goes smoothly
John, in case if you are using HF jack stands, make sure they are not the ones being recalled.
I guess everyone is aware of this.. but still...
https://images.harborfreight.com/hftweb/recalls/Jack-Stand-Recall-56371_61196_61197.pdf
Nick- we don't need no stinking brackets!
Actually my fuel filter has been next to the trans since I bought this car and even on my squareback. Haven't had one in the engine compartment since the mid 90's.
Matt- tune up will go easy- most of the time will be spent balancing the carbs.
As soon as that harbor freight recall came out ( both of them) I checked my numbers. I'm all good.
Good to hear John.
Finally got around to returning mine, although I have been using them for years on some heavy vehicles  before the recall; maybe my set was ok, no wobbling like others reported, nonetheless, returned them. Wish I got cash back instead of a store credit.  I always have my jack up and lightly supporting the car in addition to the jack stands, just in case anyway.. regardless of the jack stand manufacturer.
Yea, Jack, I remember you telling a story on how a floor jack failed on you and the car came down upon a tire which saved ya.
At least that is how i remember it, so is good to have reliable jack stands along with a floor jack
Well Jack, as long as the car was ok...
clown
BugLuv (EdnLu)
 Took it for a short drive around the neighborhood, coughed, sputtered, died??.called wife to bring the truck and towed it home.  ROFL)
  It has to have spark or gas. One or the other. When figuring which one. Your half- way there.
    TAKEN FROM ROB AND DAVES VW PAGE.
One of the most common laments we hear is, "My Bug won't start! What's the matter!?" We have found that in most cases the problem with a non-starting VW Bug (and most any car, for that matter) boils down to "fuel and spark" -
   Is sufficient fuel getting from the fuel tank, through the filters, through the fuel pump, past the float needle valve, through the carburetor, and through the intake manifold to the cylinders at the correct fuel-to-air ratio? and -
   Is a good hot spark getting from the battery to the coil and on to the distributor, through the points, rotor, ignition wires and spark plugs, and into the cylinders at the right time?
Problems in any of the above areas related to "fuel and spark" can result in an engine that won't run.
Condition #1 -- The Starter Motor Doesn?t Run and the Engine Will Not Rotate.
Following are some possible causes of a starting problem, with references to procedures and/or discussion that may help resolve the problem(s) (yes, problem(s) -- rarely is it only one). (This list is probably not all inclusive.)
Possible causes -
The battery may be dead. This is the single most likely cause of the starter motor not running and therefore the engine not running. If you have a Volt-Ohm meter, place the leads across the battery terminals with the meter set to ?volts.? A fully-charged battery should read about 12.5V; at any reading lower than about 10V the starter motor will not turn over or will do so very weakly -- and the plugs will probably not fire.
The battery terminal connections may be loose or corroded.
The grounding straps (including the tranny-to-body strap near the nose of the transaxle) may be corroded/loose/broken.
The starter solenoid may be faulty. If the starter clicks but doesn't turn (especially in hot weather), and if it can be freed up with by tapping the solenoid with a hammer and then trying the starter successfully, the solenoid is sticking.
The starter motor may be faulty (see below).
The ignition switch may be faulty. The electrical path for the starter runs from the battery up to the ignition switch and then back to the starter. Any fault in the ignition switch may prevent the solenoid from getting power to operate the starter. If the starter turns fine when the thin wire on the solenoid is shorted to the thick red wire, then you can suspect the ignition switch. See our article on Ignition Switch Replacement.
The most challenging thing I had going on is my 71 car would do that, but then start.. then die whenever it wanted to.
I eventually tracked it down to the  1 or 2 strands left on the grounding wire inside the distributor - Hopefully Ed, your prob will not be that unusual...
Something easy like fuel pump, coil..... my guess is fuel.
Good luck, let us know how it turns out-
BugLuv (EdnLu)
Thx for the pointers guys. After it died it would barely crank. On trickle charge. Needed a jump to get it started at Sweetwater. Thinking it?s electrical. Fuel pump is not very old but will check it out. It?s usually the simple stuff right? idea\
Rick
Good day folks. Starting to work on my car and I need advice on where to purchase weather stripping for 1972 super convertible and where to go to get it painted in South Jersey area.
Thanks, Rick
