Soaked the upper hinge pin on the right door of the Bug today
with PB.  Already had tried WD-40 and Liquid-Wrench with no
success.  &m& m-d2 m-d   Will try to remove the pin tomorrow.
Tried the Air Hammer method also, all it did was splatter rusty
oil all over the door and fender.
Will use the giant C-Clamp method tomorrow morning and try to
push the pin out   :wallbash:
Yuma  ( Sonny )
50split(paul)
did the front brake shoes on my 63. i found out after the driver side was done that the two remaining shoes were for a later year beetle. oh well one side is done. busicon2
Quote from: scarecrow on September 28, 2009, 06:51:24 PM
Replace my alternator with a used one (guaranteed good) now all I need is the new voltage regulator I ordered. Then I?ll see if I get something more the 12.75 volts  888
Yes  BO**  P#3 I now have 13.5 volts @ idle & it goes to 13.7 or so when reved :icon_sunny:
Went to the garage, got a flat blade, put it under the seat and pulled my seat out. Took about a minute, because it comes out through the back, not the front  P#3 P#3
Put screw driver away and got a cold beverage and watched the Phillies  BO**
Hope to do the seats this weekend...
I created new curses removing snap rings.
Checked my car at 5:30 AM 'cause I looked and said to myself "Hmmmm, I don't remember leaving that gate opened" Meanie was sleeping comfortably in the back yard  &&&&
Tip O the Day... Charcoal Lighter is a great penetrating oil. It is so thin it migrates into the smallest voids.
Tip O some other day. When trying to free stuck screws or bolts, a good hit (brass hammer or punch)  ./// can rearrange things at the molecular level and can make it easier to loosen
Happy Day   BO** BO**
Got the pin out of the right upper door hinge, installed new pin
and right side mirror.
Went down to Discount Tire, 4 new 165R15's , then over to
WM for a new battery.
Expensive day, but well worth it   P#3
Came home, washed the Bug, ready for the  vwlogo  88*88 cruise tonight.  drive&&
Yuma    ( Sonny )
slowtwitch
cleaned up the old tag, for my 57.....
pete
Early this morning I turned on the air compressor and cleaned the floor in the garage and all the dust on the Rod and did a little sanding, tomorrow I plan on putting the car on jack stands in preparation to paint it. I did buy the paint last week at tractor supply in Millville but I have to go back for the hardener, I've bee trying to get there for the past two day but didn't make it, maybe tomorrow. I have to touch up a few spots with bondo and a little more primer also. I'm still not sure if I am going to two tone it or not.
slowtwitch
John, I just may go for one  LAUGH@
I finally took my oval for a spin.......around my desk..
pete
Its finally in, and no its not a water heater or a big muffler just the new gas tank for the Bradley
just a few thousand small things to finish and then I can get the engine back in..
Ripped all the covering and stuffin off the pass. seat. Looks like somebody did two layers of who knows what... Figuring out how much I'm gonna do to the front end... Might just keep it stock.. s#r
Stacked a cord of firewood... where's the Advil?
  Retuned my vert engine.
  Looking good Bob!
QuoteLooking good Bob!
thanks Matt,
My knees are killin me, I'd give anything for a lift!
