0 Members and 44 Guests are viewing this topic.
Might I suggest that a shortened hood prop-rod from a modern car would work well and be very clean?
Or you can remove the latch from the body, mound it in a tube that can be slid out and locked in place with a knob, thus raising the actual position of the latch. Just reach under the car turn knob, raise decklid to desired height, tighten knob
Man I miss the smileys
Jack Kessel
Quote from: Baha (Shawn) on July 16, 2010, 07:58:19 AM
You wouldn't be insinuating that my board isnt clean looking, would you? (;
I don't know Jack, ask Shawn
Nah don't have those parts laying around, but I am going to add a second clevis pin to hold prop in place when not in use instead of the c clamp
Jack Kessel
Quote from: scarecrow on July 16, 2010, 08:30:55 AM
What! the c-clamp is killer....cant get more rat then that.
OK, the  c clamp idea was just a tad too crude even for my sensibilities & awkward to use. Large washer is slotted & ground down on the ends and goes in last to act as a wedge & make everything tight. Drilled a hole for a zip tie so it can't vibrate loose & fall away. When not in use I just fold the prop in, turn the clevis pin the other way & install clip. All that shows @ that point is one hole & the top of the pins.
I still think this is the way to go
For when I want to open those 7 oz. bottle of Coke
Added a HULA GIRL Today
He had to... I wasn't giving up Liliuokalani.
Quote from: Baha (Shawn) on July 16, 2010, 10:35:49 PM
Hay thats her how did you get to change her dress.
Jack Kessel
Quote from: Evil-Tunes on July 17, 2010, 06:02:14 AM
The girls don't call him slippery hands for no reason.
Jack Kessel
While working on my deck lid prop I had to turn the air down, was getting to chilly.
Jack Kessel
On my way out to the garage to put swivel footed adjusting screws on the straps engine.
