photo test
Started by 3Gear, February 01, 2010, 07:59:32 PM
0 Members and 4 Guests are viewing this topic.
thisis a test from the tech session
Hi Marc
I tried photobucket. It will not let me copy photos! -55] I then tried Picasa. I was not crazy about using it. What is the web sight you use? Maybe I'll have better luck with it.
Dagerm
I have photobucket and was able to copy a photo after I downloaded it. Maybe I don't completely understand what you are trying to do..... 2CENTS
When I tried to copy a picture to photobucket, it said there was an error. I tried a couple of times, and it said the same thing.
When I got out of our web sight I'll try again.
I tried photobucket again. It says "Image upload failed. A network caused your upload to fail" m-d I don't know what they mean by that. m-d2
Dagerm
Ok, I thought you meant copy FROM not copy TO. I've had that happen before :wallbash:. I just tried again later and most of the time it worked P#3. Also if you are trying to upload 50 pics at once try uploading 10 at a time.
Dagerm
OOPS..one more thing. Check your pic format. Photobucket will accept most but not all formats. Your pic may be in the oddball fomat. The formats accepted are listed. I can't remember where the list is but you can always click help S@Sm on the site.
Rich,
    The site I used in the demonstration was http://www.flickr.com/  After you upload the image you would view it, and right click, select properties and copy the address(URL).  You would then paste that address in your post between the img /img (brackets are removed to show the text) When I get a chance I'll play around with photobucket and see if I run into any issues.
Cheers,
MArc
Rich I use photobucket to upload my pictures and I've never had a problem. There should be two options, copy image and copy image address. You want to copy the image address.
Quote from: Beetleboi -Greg- on February 03, 2010, 08:53:12 AM
Unless of course, you're using a PC.   @7@
Greg always seems to forget he uses a Mac
You should see me at work trying to help people with their PC's. It's shocking how much you forget after just 4 years.
LOL Mac's were made for people who do not want to know how to use a computer...
I used "FlickR". I'll see what happens when I post this.
