Rich, your bus........
Started by rich67vw, July 05, 2010, 04:56:03 PM
So what if its 100 degrees out, time to work on BlueBelle:
Finished half azz-gas pedal linkage:
Started loossening up rear brake drums and shock bolts - Lower one is a b*tch.
Start making it pretty inside, oh man, it's an oven in there, forget this..
Good day to bake a Super Beetle windshield seal
Gets real pliable in the sun, borrowed some hands and got it right on...
Maybe I'll trace some wires after dinner once the sun goes down... whew!
Jack Kessel
QuoteFinished half azz-gas pedal linkage:
Thats not half azz, thats a Full azz job!! (-;
I don't know Jack, ask Shawn
BTW, take a peek at the last photo, top right hand corner, above the battery and the ground bolt. WTH is that thing?
Quote from: GlowBug (Rich) on July 05, 2010, 09:53:10 PM
Thats the plug that sends the wires up front! Well the socket anyway...
that is your BRAIN!!
or computer...if you want to be technical
or a Bosch L-Jetronic computer/brain if you want to be super geeky ;-)
Quote from: Baha (Shawn) on July 05, 2010, 09:56:40 PM
Oh no. not more electrical. I was hoping it was some old VW diagnostic block..
Hmmm. Can I borrow the way-back machine that took this web site back to March? I wanna go back a few years and beat the livin tar out of the PO's of BlueBelle...
Quote from: ykuday on July 05, 2010, 10:08:43 PM
My first brain surgery! I was curious tonight so I yanked it out seeing it had no wires connected to anything... One of those Hallmark cards that plays a song when you open it probably has more capacity than this thing.
Sorry... Bus newbie here. Forgot FI bus has brain. Not yours as I see carbs.
So you're brainless... But its OK
My Bus still has a brain. Sorry I could'nt help myself
Quote from: Baha (Shawn) on July 06, 2010, 10:08:03 PM
BlueBelle was an original FI Bus, based on the gas tank outputs thats in there. Must have switched out to a dual carb engine...
Quote from: GlowBug (Rich) on July 07, 2010, 08:57:01 PM
Or just pulled it cause they didn't understand it...Very common
Quote from: Baha (Shawn) on July 07, 2010, 09:03:42 PM
Yep!
Glad you are making progress Rich. I'm going to order my brake stuff with my play check. =-p
Greg - Lemme know the date when we are going to do your brakes - I can help ya...
