Pages: 1 [2]   Go Down
Author Topic: An update.  (Read 10733 times)
Re: An update.
« Reply #15 on: July 29, 2010, 10:55:40 pm »
Yes I did! Thanks for asking...did you ever get all your tin?
Re: An update.
« Reply #16 on: August 09, 2010, 12:25:40 am »
I dunno about all the tin. might be one short. split the block tonight, here is what I found.....
« Last Edit: August 09, 2010, 12:29:44 pm by rockdog2877 »
Re: An update.
« Reply #17 on: August 09, 2010, 10:34:24 am »
I can't make out what your showing (chunk of bearing) but it also looks like the rear main bearing was spinning in the case. I sure would like to come up and check it out before you put it back together.
« Last Edit: August 09, 2010, 10:43:31 am by LoveBus (jack) »
Re: An update.
« Reply #18 on: August 09, 2010, 12:31:07 pm »
the one picture has a hunk of the rear bearing.
the bottom picture I was showing the cam bearing was down to the copper.
Feel free to stop by anytime.
« Last Edit: August 09, 2010, 01:17:06 pm by rockdog2877 »
Re: An update.
« Reply #19 on: August 10, 2010, 12:32:25 am »
what's the best way to get a seized bearing off the crank?
lol a new crank?
Re: An update.
« Reply #20 on: August 10, 2010, 09:11:56 am »
Is it a half or whole bearing? Probably whole! I have cut them off using an air powered cut off wheel, using a wheel the is very small (almost worn out). Don't touch the crank!!!!!!! When you get close carefully knock it off with a small chisel.
Good luck,
Bob "Herbie"
Re: An update.
« Reply #21 on: August 15, 2010, 12:26:16 pm »
Take it to Jack's.
Re: An update.
« Reply #22 on: August 15, 2010, 02:21:15 pm »
yeah, when I see an old broken crank, I think of Jack.
hee hee hee!
Re: An update.
« Reply #23 on: August 15, 2010, 02:25:10 pm »
hee hee hee!
Re: An update.
« Reply #24 on: August 20, 2010, 09:02:49 pm »
Pages: 1 [2]   Go Up
