Author Topic: 1979 VW Bus For Sale  (Read 9903 times)
« on: November 10, 2010, 04:40:02 pm »
1979 VW Transporter.  Case code on motor indicates that it's an 1800 not the 2000 that it should be. Also has round port heads & 75-78 heater boxes. Fuel injection intact & working perfectly. Runs & drives perfectly. All electrics and gauges work properly. All of the following has been done.
1,000 miles on the new & correct Hanhook A008 tires. New brakes, drums, rotors, calipers & rubber lines. New shocks. Steering box replaced with a better used one (1/2" of play now instead of 3")
New battery, oil cooler, double relay, fuel pump, fuel regulator, air flow meter & injectors. All fuel lines replaced.
Has MP3 compatible stereo, CB radio & running lights.
Downside, usual Bus rust on dog legs, under sliding door & under tail lights. Windshield is cracked on passenger side. (Never bothered me any had no intentions of replacing) One of the sliding windows is plexiglas but I have a good used one just never installed. Transmission works perfectly but shifter is sloppy. Needs bushings.
Also comes with original front & rear seats & a couple of rust repair panels.
Being offered here first for.
« Last Edit: December 15, 2010, 06:10:16 pm by scarecrow »
Re: 1979 VW Bus For Sale Or Trade For 1960 to 1970 Detriot Iron
« Reply #1 on: November 11, 2010, 11:02:09 pm »
I'd think about it, but that paint is just TOO shiny. :)
Re: 1979 VW Bus For Sale $2,500
« Reply #2 on: November 21, 2010, 08:06:24 am »
Hey Rich you need to buy this Bus
Re: 1979 VW Bus For Sale $2,000
« Reply #3 on: November 21, 2010, 06:13:59 pm »
« Reply #4 on: November 21, 2010, 09:20:45 pm »
Do you take visa?
« Reply #5 on: November 21, 2010, 10:12:27 pm »
« Reply #6 on: November 21, 2010, 10:24:39 pm »
I still can't believe your selling it. )-:
« Reply #7 on: December 13, 2010, 11:40:23 am »
how did the Ebay go....
« Reply #8 on: December 13, 2010, 12:01:53 pm »
Got stiffed  &(rage_ I just don't understand why people who have no intentions of following through bid %heascratch%
OK, Bus is no longer for sale. Even if I say it's for sale it's not
Plus the wifey say no way So I'm keeping it
« Last Edit: December 18, 2010, 10:43:33 pm by scarecrow »
« Reply #9 on: December 13, 2010, 12:20:06 pm »
Same thing happened to me when I sold the fastback.  It is annoying.
