Author Topic: engine stand @ harbor frt $36.00  (Read 15054 times)
Re: engine stand @ harbor frt $36.00
« Reply #1 on: January 16, 2011, 01:38:52 pm »
Theres a scaffold part I have at works that makes a PERFECT adapter to use the Empi Bench Mount engine holder in this stand.
Let me know...I'll get you one
« Reply #2 on: January 16, 2011, 05:00:05 pm »
I'm all set, thanks Shawn
50split(paul)
« Reply #3 on: January 16, 2011, 11:37:02 pm »
i could use the scaffold part. i need to adapt my engine holder to fit the h.f. stand.
« Reply #4 on: January 17, 2011, 08:36:11 am »
Why spend all the time you work trying to get different parts to work together when you can spend $100 and get something that works great with no hassle like this, http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-1411
50split(paul)
« Reply #5 on: January 17, 2011, 10:12:13 am »
i need to adapt my bench mount to my h.f. stand. hopefully what shaun has will help.
any photos of the part?
« Reply #6 on: January 17, 2011, 10:59:58 am »
only photo is by clicking on the link, can't copy CIP1's photos.
« Reply #7 on: January 17, 2011, 12:41:46 pm »
Its called a base collar
Theyre chinese import and as a result the large tube fits perfectly into the HF stand bushing and the Empi motor bracket fits inside the small end (I cut it right at the rosette ring)
Because this just slides in and is held in place by pins, the HF stand can still be used to hold other motors with it's original motor bracket. So it's more versatile
Great if you have a bench mount already... But Jack is correct if you were buying both
50split(paul)
« Reply #8 on: January 17, 2011, 10:39:01 pm »
i have the bench mount stand and the h.f. floor stand. i need the base collar. can you get one?
« Reply #9 on: January 18, 2011, 08:51:20 am »
Yup... as soon as the docs let me go back to work
50split(paul)
« Reply #10 on: January 18, 2011, 04:32:57 pm »
groovy...if you can snag one let me know what i owe you.
« Reply #11 on: January 18, 2011, 06:35:18 pm »
Just saw this in the JC Whitney VW Mag $35.00
EMPI BENCH ENGINE STAND FOR VW AIR-COOLED/PORSCHE ENGINES
« Reply #12 on: March 09, 2011, 08:49:22 pm »
Paul,
I have that base collar you wanted
50split(paul)
« Reply #13 on: March 09, 2011, 09:22:08 pm »
thanks, can you send it out or should i pick it up at englishtown in april?
50split(paul)
« Reply #14 on: March 14, 2011, 09:33:29 pm »
Paul,
cool, what now???????????
