Author Topic: 90 Cabriolet- Timing...Are we barking up the right tree?  (Read 3695 times)
« on: October 05, 2011, 10:09:23 pm »
OK Great and Wise VW Gurus... Do we have something here????
When I looked at this car (before Marc bought it) the PO told me
"I just cant get it running right, and Im tired of messing with it."
So Marc and I went hunting. We highlighted all the timing marks.
Then we brought the #1 piston to TDC
Are we crazy??? Or is the cam way out of whack?
vwnutt
    • DOTB
Re: 90 Cabriolet- Timing...Are we barking up the right tree?
« Reply #1 on: October 05, 2011, 10:47:17 pm »
 :confused04:;
I think we need to consult the Bible Bentely
How many Marks are there?!?!
« Reply #2 on: October 06, 2011, 06:29:16 pm »
 :confused04:;
« Reply #3 on: October 06, 2011, 08:26:26 pm »
It looks as though the engine was on # 3 instead of # 1 when they lined up the marks. To confirm this rotate to # three and see if the marks line up correctly. If this is the case you know why it runs bad but close enough to run!
« Reply #4 on: October 06, 2011, 08:42:15 pm »
Thank you Bob.
Well I guess we know why it drove him crazy.
So, technically I can take the belt off, move the cam, put the belt on (without moving anything of course) and it should be good.
I mean we need to rotate twice manually to make sure there's no "clearance" issues and also to make sure the marks do what they're supposed to
Right?
« Reply #5 on: October 06, 2011, 08:55:45 pm »
Correct! On all points. Just make sure you are on # 1 TDC. Should be easy peasy. Good luck!
vwnutt
    • DOTB
« Reply #6 on: October 06, 2011, 10:24:50 pm »
 clap2-*
See we CAN work on water pumpers!!
« Reply #7 on: October 07, 2011, 07:47:13 am »
clap2-*
Right... Remind me when you get there that we spun the intermediate shaft, so the distributor is probably off now  ?/banghea?/
vwnutt
    • DOTB
« Reply #8 on: October 09, 2011, 10:40:30 am »
So it runs a lot better than it did, looks like the timing was off by about 90*?
Now we have to work on setting the air fuel mixture and she should be 100%
 &^beer&
« Reply #9 on: October 09, 2011, 05:17:20 pm »
Is that a CIS? You need that long allen wrench to adjust the air/fuel if I remember correctly! I have one some were?
« Reply #10 on: October 09, 2011, 05:46:12 pm »
Digifant
« Reply #11 on: October 09, 2011, 05:56:47 pm »
Watch your mouth, this is a family forum....  #@rofl3
vwnutt
    • DOTB
« Reply #12 on: October 09, 2011, 08:02:45 pm »
Digi II to be precise.
