Author Topic: Cover 'Em Up Cruise- SJ Countryside & Wheaton Glass  (Read 15058 times)
« on: November 17, 2012, 12:23:38 pm »
Don't miss the last official cruise of the season.
We'll wander out through the South Jersey countryside & make a stop at  Historic Wheaton Village.
Breakfast at Geets' Diner at 8:00 AM & we depart at 9 AM.
Hope to see you there
Re: Cover 'Em Up Cruise- SJ Countryside & Wheaton Glass
« Reply #1 on: November 17, 2012, 02:58:02 pm »
Anyone?
Helloooooo   oooooooo                            ooooooo                                                  oooooooo
« Reply #2 on: November 17, 2012, 03:43:10 pm »
See you there
« Reply #3 on: November 17, 2012, 10:01:57 pm »
Sorry, can't  make it.  Have a great time   thumpup)-
« Reply #4 on: November 17, 2012, 10:14:45 pm »
 &(rage_  can't make it! My starter dragging really bad. now i have 3 starters in my garage, none good!  &(rage_
« Reply #5 on: November 17, 2012, 11:39:16 pm »
   I won't be going. Old blue won't idle and runs awfull.
 I tried fixing it today. I Found that #1 plug not firing. First; sprayed carb cleaner down the Dellorto barrel that feeds #1 cylinder-no increase in RPM. Second; pulled spark plug -great looking, good tan color-good mixture, no sign of misfire. Third; pulled valve cover, thinking the spring clip came off, moving the rocker arm off valve (it happened once before) Nope, that wasn't it either.  :confused04:;
 I'll try a compression test next. if that's okay, repeat the process. Fuel, spark or mechanical, it's got to be one  (or more of them).
« Reply #6 on: November 18, 2012, 10:14:41 am »
Check your starter bushing.
