ok well I got around to adjusting the valves on the bus. I got through #1 and #2, with little trouble. (#2 was very tight)
I went to start numbers 3 and 4, I realized the valve cover spring was not going to go down past the heater box. I installed the 74 style and this was the first time I had tried. I pushed it up knowing I would regret it later. the first thing I noticed that it was missing the small thin clip that sits around the push rods. I had a spare floating in my parts bucket, and when I went to install it I noticed this.......
the assembly seems to be wrong. the "space" is on top. do you think this will be aproblem, should I leave the clip out?
any tips on getting the clip down over the valve cover?
(milo) Ghug fig2 busicon2 sqBk fast@#
