0 Members and 30 Guests are viewing this topic.
Quote from: LoveBus (jack) on January 05, 2011, 04:28:02 PM
Finally got my lazy butt in gear and took the fuel pump off the Rod and put a pin with clips on it, no more pin coming out!!
Shame... We kinda like hangin out in parking lots talking
Searched the Samba on how to replace an oil cooler with engine in Bus.
Quote from: GlowBug (Rich) on January 05, 2011, 08:57:49 PM
I've done that. Not hard. I posted everything with pic's but may have been lost when the sight crashed. Will check to see if I still have pic's on my PC some where
Quote from: scarecrow on January 05, 2011, 10:09:23 PM
It's in your blog silly...
Quote from: scarecrow on August 09, 2009, 07:37:24 PM
I was dreading this job but it was no where near as bad as I thought it would be.
Remove muffler
Remove fan
Remove 3 pieces of cooling tin
Remove oil filler tube
Remove coil
Remove front half of fan shroud
Disconnect cable from thermostat
Remove bottom alternator bolt
Now your down to 4 bolts that hold the back half of fan shroud
Remove these & tilt shroud towards right being while be mindful of harness to alternator
Remove 3 nuts holding oil cooler, remove cooler
Replace oil cooler seals, install & bolt down new oil cooler
Reverse procedure to put back together & your done. Takes up the good part of an afternoon to do.
Somebody post something else, I can't look... :(
Well you don't know where it came from, itcould be the oil filter, or the oil pressure gauge. ( yes I am just trying to make you feel better)
Asking the stupid question here.....
Was it just oil? When my fuel pump diaphragm on the "Blue Mule" went it filled the crankcase full of gas & it leaked from everywhere
All oil Shawn. Thx though. I have an idea.
Still think it's chocolate syrup... are you sure it's oil? Maybe I'm just hungry.
Quote from: GlowBug (Rich) on January 06, 2011, 09:11:42 PM
I think its a cracked block (0:
ARGGGGGRRRRRRRR.........
If that statement just became true due to the mystical "Power of Jack", I'm coming after ya  :)
 :confused04:; Well you said to:
 HAY, lets us not forget, IT STARTS NOW!!!! {}congrats
